Can't receive or make phone calls again, how to fix it asap?
GCH1
I can't receive or make phone calls again, please fix it asap.
13 REPLIES 13
hi @Me29
so , you are @GCH1 ?
A8 should be compatible and should not have problem.  Did you submit a ticket with PM support agent and ask them to refresh your account?
But since the sim card works on another phone, it makes me think it is more a device problem
Me29
samsung galaxy A8
HI @GCH1
what phone you have?
GCH1
I can't make and receive calls. When I insert my SIM card into another phone, it works. When I insert another SIM Card with another carrier, I can make and receive phone calls. So, it seems PM issue.
Me29
Thank you
hi @Me29
you should ask support agent to check and refresh the account
please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
@Me29  So it’s account issue or you need new sim and you said you submitted a ticket so keep n eye on your community inbox for supports reply or
you can use this link to the community in box
Me29
I also couldn't make calls most of the day yesterday, but last evening it worked. Now again I cant make calls
Me29
I tried my sim in his phone. No luck
@Me29  Can you try his SIM card in your phone ? And you sim in his phone ? Will help to determine if it’s account related or device issue
Me29
Thanks I've done literally everything you suggest. It cant be an outrage because my bf uses the same carrier and his phone works
@GCH1 can you confirm your account is active and not suspended? Try rebooting the phone or reset network settings . If possible can you try sim card in another phone to test ? Can also try phone set to 3G and see if the helps for voice
also check
Outage map in your area:
https://istheservicedowncanada.com/
if account is active and there’s no outage in your area and rebooting device or reset network settings doesn’t help
please
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send  direct  private message to support .
send  a  private message   To CS_Agent
hi @GCH1
data works? you sure account active?
Reboot your phone and Reset All Networks  might help
if not, you really need support to help, you can  submit by direct message:
