03-09-2021 04:58 PM - edited 01-05-2022 05:33 PM
Switched from Freedom mobile to Public but Freedom mobile is still active. I call make out going call but I can't receive incoming call using public phone. How can I disconnected previous provider and can receive incoming call with my new public phone ?
05:52 PM
10-09-2023
08:37 AM
I would try the porting helpline, but first try to reboot device and remove and replace SIM card.
03-09-2021 05:41 PM
03-09-2021 05:37 PM
Try to reboot the phone again. Freedom will need to port your number over to PM. Be patient.
If it doesn’t work, log on your account and contact a PM mediator.
03-09-2021 05:34 PM
@abukamal wrote:I did whatever you said. I got message and replied yes. but still not complete. How can I make it complete ?
@abukamal How long has it been? Put your old sim in the phone and keep using it until it stops. THEN put in your PM sim. If it has been more than a few hours contact a moderator for help.
03-09-2021 05:26 PM
03-09-2021 05:25 PM
Thanks. Yes I received message from previous provider and I said yes.
03-09-2021 05:16 PM
@abukamal wrote:Switched from Freedom mobile to Public but Freedom mobile is still active. I call make out going call but I can't receive incoming call using public phone. How can I disconnected previous provider and can receive incoming call with my new public phone ?
If you just ported your phone number from another cell provider it could take a few hours to complete the port.
Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
Incoming calls are usually the last to port over.
Make sure you do not cancel your previous provider's services until the port is complete.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
03-09-2021 05:08 PM
@abukamal Your porting is not complete. You need to keep the old SIM and wait for a text from Freedom to confirm you are porting over to PM. Once you confirm with YES, power off the phone and replace the old SIM with the PM SIM then power up the phone. You are ready to go.
03-09-2021 05:06 PM
@abukamal hi when you port a number you must leave your old sim in your phone to receive a text from them asking if you wish to port your number did you get the text?
