Can't receive calls or texts after porting
09-18-2018 10:05 PM - edited 01-05-2022 01:50 AM
09-19-2018 10:09 AM
you likely have a temp number given to you. this happened to me. Visit local walmart to have them call help desk & persue issue
09-19-2018 09:38 AM
Try restarting the phone if it is still not working contact the mod_team.
09-18-2018 10:08 PM
@Raknirok wrote:Help it's been over 24 hours
Your port is stuck. You will need to contact the mods. The current response time is around 48 hours. In the meantime your old SIM is probably fully functional, i would try it in your phone and use that until your port is completed.
- PM Phone Number
- 4 digit PIN (if you don't remember this then they will need at least 3 of the following to verify your identity)
- account number
- date of birth
- complete address listed on account with postal code
- email address on account
- most commonly called numbers
- alternate number listed on the account
- last payment date and amount
- last 4 digits of the credit card
- Detailed explanation
09-18-2018 10:08 PM
If you are porting from a mobile line, it should have ported within 2-3 hours. If it is a landline or VOIP, then 1-2 days.
You likely need to contact moderator to help complete port. Expect 1-2 days wait.
send a private message through the following link :
Please include in the private message your phone number, your account number and PIN code.
