09-21-2016 08:11 PM - edited 01-04-2022 03:32 PM
Hey there,
I just switched over to Public Mobile yesterday from Mobilicity. Data, outgoing calls, and sending and receiving texts works. But I can't receive calls or send picture texts.
I'm using an ASUS Zenfone 2. Any help would be greatly appreciated!
09-23-2016 02:52 PM
So receiving calls and texts works now, but I still cant send any picture texts, it gets stuck at "sending" and never gets sent. been trying to change the APN settings but nothing seems to work!
09-23-2016 01:59 PM
Thanks Shazia! I'm going to test calls and texting, hopefully it works now.
09-22-2016 09:49 AM
Hello @OKJoy,
I'm sorry to hear about the porting issue,
Can you please send me a private message with:
-The number you are porting
-Account number with previous provider
Thanks,
Shazia
09-21-2016 11:48 PM
Hello there,
There was an issue porting your number which is why you are not able to recieve anything. Please make sure your number is active and that the account number, imei or pin your provided for porting the number is correct. If you have disconnected the number with your old company your will need to make it active and try porting again. You can redo the port of the number in self serve; under the plans and addons tab you can find the change your number and redo the port from there.
Cheers,
Rick
09-21-2016 11:37 PM - edited 09-21-2016 11:41 PM
Thank you for the quick response JaK, I just tested it, I can' t receive texts either. So it looks like neither texts nor calls can be received.
09-21-2016 08:30 PM
