11-10-2016 04:20 PM - edited 01-04-2022 06:12 PM
Ported over my number from Rogers last night. I can make calls and the data is fine but I can't receive any calls. All calls go straight to my old Rogers voicemail.
Sent messages to a few Mods already and filled out the Contact Us form so here's my last method of messaging the moderators/Public Mobile staff!
11-19-2016 04:20 PM
@Rockdaddy22 I think @jeffhon had his problem solved in a different thread.
11-15-2016 11:51 AM
11-15-2016 11:48 AM
Hey @jeffhon
Glad to hear that everything is now functional 🙂
Don't hesitate to send us a message if you have any other questions.
Cheers,
Mary
11-10-2016 05:51 PM
Thanks for the tips! Unfortunately my Rogers SIM card is too scratched up to work so I can't test those options for you.
11-10-2016 04:43 PM
Expect a delay of several days.
So suggest:
a) use your Rogers SIM; if it still sends & receives calls just use it until it stops, or
b) use two phones, or
c) get app from fongo.com, then forward Rogers to it; answer incoming on fongo & call on Public Mobile.
Please let us know if option a) actually works. I have forgotten.
11-10-2016 04:23 PM
@jeffhon you've done the right thing by sending the mods a private message, thats the best way to get your issue resolved. Unforuntately due to high volume the moderators are swamped adn taking longer than normal to get to your issue.
Make sure you've provided them with all the info they require per the below thread.
Also another thread with contacting mods and getting their attention.
