06-18-2018 12:17 AM - edited 01-04-2022 06:12 PM
Hi everyone,
This is a problem I had for a while. Does anyone know whether one could have two phones which both have the same number? That is if someone calls both phones will ring and you can make a call using any one of the phones. Or is this impossible?
Thank you 🙂
06-18-2018 08:57 AM - edited 06-18-2018 09:01 AM
You could set this up using Fongo. Fongo allows you call forward to more than one number. So you can set it up to ring both cell numbers if someone calls your Fongo Number. Fongo is free and this feature is inlcuded in the free package.
06-18-2018 01:19 AM
06-18-2018 12:36 AM
If only Google voice was officially available in Canada. The effects of having the same number on two or more devices for that matter would be possible through the forwarding service.
06-18-2018 12:28 AM
A similar thread on PM forums as well. Click
But to answer your question, no. It has to be one number/simcard
06-18-2018 12:26 AM - edited 06-18-2018 12:47 AM
@Cheetah24 FYI, please read this: Two sim card with same number
Seems like it is possible in UK. ![]()
EDIT: Found one more interesting thing to read: How to Have Your Phone Number Ring on Multiple Devices
