02-10-2023 10:55 PM - edited 02-10-2023 10:57 PM
For about 2 days I have not been able to make or receive any calls. This started between calls and I did not make any changes to settings or run any updates on my phone leading up to the issue. I can send/receive text messages and cellular data is working fine.
I have tried the following:
-power cycling phone
-turning on airplane mode, waiting 30 seconds, turning off airplane mode
-reseating SIM card
-resetting network settings on phone
I have also checked my account. Status is Active and have unlimited Canada-wide talk.
02-10-2023 11:09 PM
could be a temporary local network interruption. Which area are you in ?
02-10-2023 11:08 PM
Hi @rob0114
try to selecting network '3G only' or WCDMA only,
and rebooting phone.
02-10-2023 11:02 PM
02-10-2023 10:59 PM
try your public mobile Sim card in someone else’s device.
And while you’re at it, try their Sim card in your device.
This should help establish whether you have a device or an account issue.
