Can't make or receive calls
06-29-2019 04:13 PM - edited 01-05-2022 05:39 AM
Hey,
Is there a system wide outage? Or is it just me?
I'm on a OnePlus 3T, I couldn't make calls this morning and I wasn't able to receive a call.
Whats going on?
Phones
06-29-2019 09:06 PM
@RossN wrote:@will13am you are welcome to your opinion but if we are just going to send them to the moderators eveytime without trying to help we may as well shut down the community and set up a recording to contact the moderators
The community was all about helping customers with non account related matters. Some of these work arounds are to address account problems. As I said we are potentially enabling the survival of long standing issues. You think this kind of response from customers is a good thing?
https://productioncommunity.publicmobile.ca/t5/The-Lounge/I-m-done-with-PM/m-p/368891#M1573
06-29-2019 05:30 PM
06-29-2019 04:39 PM
@Alvito , it could be a local issue but definitely not a system wide outage. If the issue is plan related, I would suggest going the official route and have the moderator team look into the matter. I used to think it's great to do work arounds like lost phone, add a buck. These strategies if they work is an enabler for Public Mobile to ignore issues. By reporting it officially, it makes it harder for them to ignore problems than if they don't even see it. Outcome may be identical, but at least they are made aware.
06-29-2019 04:31 PM
@Alvito wrote:I am unfamiliar with this method. Please explain further.
1. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to provision your account again. i.e. enable all features of you plan again.
If this trick failed to get thing working again, you should send a private message to moderator for help. But the wait is up to 48 hours. Good luck.
06-29-2019 04:24 PM - edited 06-29-2019 04:26 PM
@Alvito go into your account where it says change number it is in that section sometimes adding 1 dollar seems to work also
06-29-2019 04:21 PM
06-29-2019 04:20 PM - edited 06-29-2019 04:21 PM
@Alvito try the lost stolen trick it may wake it up wait five min then press found
06-29-2019 04:19 PM
Public Mobile greets me and tells me my next payment is due in September, then gives a bunch of options.
06-29-2019 04:18 PM
I'm on a $40 plan that includes:
12GB Data
Unlimited International Text
Unlimited Provincial Talk
06-29-2019 04:17 PM
06-29-2019 04:16 PM - edited 06-29-2019 04:18 PM
@Alvito What does *611 say if you call it? check your account
06-29-2019 04:15 PM
@Alvito are you on the 10 dollar plan did you run out of minutes
