Can't make calls
indi5o
What's going on.. I can't make calls
2 REPLIES 2
Dunkman
@indi5o
More details are needed.
Has talk worked before?  What about text and data?
Is your account status active versus suspended?
Maybe try rebooting phone.  Use prefix 1 in front of area code and number
TheSterlinger
Have you just ported in? If you have then that means the porting process was unsuccessful. I have sent the porting department’s number you can call them and have the request resent. Check your inbox by clicking your avatar and clicking messages.
