Can't login. Max login exceeded
PM99
Hi I can't login. It says Max login exceeded. What can I do? Please help!!!
statusquo
Yes I get this problem sometimes too or I forget my password.
Hi @PM99 if you are using Chrome and used the saved password,  do not click the Login button,  let Chrome automatic login for you
dabr
@PM99   Try using incognito/private mode to login or another browser.
