04-28-2024 03:45 AM
I’ve been trying to log in but it keeps saying my password is wrong & when I go to reset it, it says I’m locked out & it keeps saying that even after hours of waiting
04-28-2024 03:51 AM
try to login using browser with Incognito mode. You might want to reset password and login all using the incognito mode and see if it helps.
You can also use the PM app. First, make sure you clear browser cache for the default browser on your phone, then uninstall PM app if it was installed earlier, reboo the phone and resintall the app and try login
If neither of the above works, you will have to check with PM support. Please open ticket with PM support:
