07-06-2023
01:58 AM
07-06-2023
03:07 AM
computergeek541
07-06-2023 09:29 AM
did you try setting 3G Only on your phone
and maybe it is device problem? try using a wired or bluetooth headphone
Try using another phone for your pm sim card
and you had no problem before ? just started?
07-06-2023 03:31 AM
Test the phone with headphones and see if this works or same issues.
If the headphones works, it could be the speakers on the phone.
If it doesn't work, it could be a hardware issue.
You can bring it into a cell repair to confirm.
07-06-2023 02:10 AM - edited 07-06-2023 02:11 AM
Try the following: reboot phone, reset network settings, reinstall SIM card, set preferred network to 3G on your phone, try SIM card in another unlocked phone.
If still issues contact an agent.
You can contact an agent:
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
