Can’t get into my account
Amandaj123
how do I get into my account when I don’t have access to my old email
8 REPLIES 8
@Amandaj123
If your account is still active, you can use the old email and password but have the 2FA code sent by text.
Other than that, you will need to contact a CS_Agent to update your email address once credentials are confirmed.
Meanwhile, if your account is suspended with no service. Purchase a voucher and enter the voucher number by dialing *611.
They can be purchased from these locations:
hi @Disallow you can
the email address is just a username. If 2FA is disabled or can be sent to your phone, you can login
of course, if the only way to get 2FA is via email, then you will need to fix the email first
Disallow
but i don't think you can log in to the self serve without a registered email, right?
dust2dust
So I guess your account isn't active or you don't have your valid sim in a phone? Otherwise, you can choose the sms option to log in. The email address is just a login id.
hi @Amandaj123
if you can send the 2FA code to phone, yuubcan still login with the email as username and password
but to change email on My Account, only PM agent can do that. Please submit ticket
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
LitlLdy
@Amandaj123 , you can still sign into your account using your old email address & password but as per @Yummy message only a CSA can update your email address on your account.
Disallow
From what I understand, you'd need to send a message to CS from here to get the email changed.
Yummy
Ask agent to update your email.
To Contact CSA-agent there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+) Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private messaging might take longer.
Watch for envelope in top right corner of Community page. It will show Number of unread emails.
