Can't get data to work
Refract
I setup the data as instructed but none of the apps work, give a "no network" error message. Data is turned on too. What's happening?
Refract
Thanks everyone for replies, it was a dumb error. I filled in "proxy" instead of "MMS proxy". Resolved.
geopublic
@Refract  If you are using an Android device post a screenshot of your APN settings.
Triguy
Have you setup the APN settings ?  When you log into your account under data and add-ons is there an amount of data showing ?
Dunkman
@Refract
Does your text and talk work?
Which model phone?
Might want to try rebooting your phone. Network reset.  If LG phone, sometimes you might need a factory reset of your phone.
Is this an iPhone or Android?
Do the other services work? Calls in/out? Texts in/out?
