12-31-2017 12:37 PM - edited 01-04-2022 03:12 PM
I created a new number through you (not a port) and after 2 days incomming calls still don't work. All I get is a message stating that "The phone number is not assigned". I have removed the SIM, restarted the phone, nothing helps. Outgoing calls work and incomming and outgoing texts and data are fine.
12-31-2017 12:44 PM
@dalehandy, sorry to hear you are having some issues. You will need to message a moderator to have this looked after.
