Can't connect to network
Ksr519
Was in the middle of phone call this morning and then heard a noise and was disconnected.  Since then I have not been able to connect to cell phone tower.  Was working since I joined Aug 6th.  I have done the network reset and nothing will allow me back on network.
Please help.
BTW, I'm on unlocked Samsung s21.
@Ksr519  They should reply with in 20 mins to 2 hours just keep an eye on your community in box for their reply . And they will ask you some verification questions to get started and just ask them to refresh your account (re provision sim )
you can  find their  reply here
Ksr519
Sent them msg to see this thread, hopefully can be resolved soon...
HI @Ksr519
too bad it is not a physical sim and nothing much you can do
Please submit a ticket with CS agent here:
@Ksr519  You may need support to re provision your sim on their end .
Ksr519
My husband has same esim and has no issues, he has s23
@Ksr519  check
Outage map in your area:
https://istheservicedowncanada.com/
also can you try the SIM card in another phone to test . If no luck please submit ticket with support
private message   To CS_Agents click
