Can’t connect to internet
11-18-2017 11:03 AM - edited 01-04-2022 02:58 PM
11-18-2017 04:40 PM
Hi @will13am,
I wasn't suggesting to do a factory reset, just a hard reboot (i.e. take out the battery and put it back in, if the device has a removable battery), I probably should have used maybe a better term than "hard reset".
I agree, a factory reset should always be the last resort due to what you mentioned, as well as the possibility that everything may not have been backed up and all that data (i.e. contacts, pictures, etc.) could be lost for good.
11-18-2017 04:31 PM
@dna2016 wrote:Hi @SharonZhao
You might want to do a hard reset by taking out the battery and putting it back in after about 10 seconds. If that doesn't work then go online and check to see if your data allowance has been used up. Also consider checking your phone settings, did you do any type of factory reset or software update recently, that could have reset your APN settings. If so then you can follow the steps below. Hopefully these suggestions and the suggestions from @Mana and @mimmo helps. If not then definitely reach out to @CS_Agent.
How do I set up data/APN on my smartphone?
In this page, you will find Public Mobile APN Settings for your smartphone.
Step by Step APN configuration
Step1:Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)Blackberry
OS 10 - Settings > Network and Connections > Mobile Network > Tap the settings icon (dented wheel)
Step 2:You will need to input the following information:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blankStep 3:
Select Save/Done. Select Public Mobile to connect to the Public Mobile network
Please don't suggest hard resets so easily. This wipes everything and can be a nightmare for many to set up the phone again.
11-18-2017 02:46 PM
Hi @SharonZhao
Step1:
Android
Blackberry
Step 2:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Server: Leave blank
MMS port: 80
MCC: 302
MNC: 220
Step 3:
11-18-2017 02:45 PM
Check that mobile data is enabled. Just the other day, a friend said the same thing to me, my data suddenly stopped working, what could be wrong. I suggested checking that first. Mobile data was turned off. Not going to judge how or why, but sometimes settings can be errantly set.
Failing this, check the account to make sure the data allotment has not been used up. After that, maybe check APN.
11-18-2017 02:36 PM
In addition to what @mimmo suggested, please check your signal.
Try enabling and disabling airplane mode to refresh your signal.
11-18-2017 11:10 AM - edited 11-18-2017 11:11 AM
reboot phone? is data used up? does the addon sho up in your selfserve? are you on a 3g plan that just renewed?
11-18-2017 11:01 AM
This morning, it cannot be connected to internet when I shut off the wifi mode? Is it PM network down?
