02-15-2026
04:29 PM
02-16-2026
12:17 AM
computergeek541
I have been trying to change my SIM card but whenever I try to change it on the app it asks for 2FA and sends a message with the code to my number which is not currently receiving messages.
02-15-2026 04:42 PM
Did you try clicking Didn't Receive Code or Resend code and see if Send email option is there?
If not there, ask PM to help. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
02-15-2026 04:36 PM
@TyceB You can get support to help you
you can use the orange chat bubble bottom right of screen or send a private message To CS_Agent
