11-06-2022 11:30 AM
I lost my phone so got a new SIM card to put in my new phone and when I go to edit my account info like I was told, to change the SIM card number it’s glitching and just goes back to zero. Since I don’t have a phone number I can’t dial 611 and the fact there’s not way to contact an agent is really frustrating. @CS_Agent
11-06-2022 01:18 PM
If changing your SIM # is like the activation process...you only need to enter the last 2 groups of numbers.
11-06-2022 11:55 AM - edited 11-06-2022 11:55 AM
Before trying again, clear your cache and cookies and open an incognito tab. When on the self-serve page, click the refresh icon and allow the screen to refresh. Then go into your change SIM card function and update the new SIM card number.
Worst case, contact the customer support agents if this does not work per the following:
11-06-2022 11:54 AM
Did you try one of these remedies?
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh. Click on little spinner refresh icons lower down.
