E-sim rewards
HarleyRose
I have a SIM card in my iPhone 13 , if I change to an e-sim with the iPhone 17 will I loose the rewards I receive from referrals I have?
1 REPLY 1
@HarleyRose
no, you won't lose anything.  Rewards is tie to your acocunt, and it is not affected by change sim
and a reminder, to change to new  eSIM for, first, download the app on your new phone and login.  If you have problem with receiving 2FA code, click "Didn't Receive code" or "Resend code" and choose either Send email or Send voice message
Once logged in, Click Account from the bottom, then click Purchase SIM Card and select eSIM.
Once it confirms your phone is eSIM compatible, click Pay $  and Install
