Can't access network
lyonsj2
Moved from the states with my phone that worked on Verizon.  Activated new SIM.  Get a message: you're phone's not registered on a network so you can only make emergency calls"
HI @lyonsj2   Verizon phones generally will work here
Verizon uses bands 2, 4, 5, 13, 46, 48, 66 which match some of PM's bands.
Maybe your sim card ?  did you try it on another phone  to confirm if it was setup correctly?
Or open ticket with PM CS agent and have them to confirm the activation (I assume you just activated?)
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
Chanah
Is it possible that your phone is still locked to verizon?
Yummy
Confirm your phone is compatible with PM frequencies
Public Mobile uses the following frequency bands:
4G LTE and LTE Advanced: 700 MHz, 850 MHz (band 5), 1900 MHz (band 2) and 2100 MHz downlink and 1700 MHz uplink (AWS).
3G/HSPA: 850 MHz, 1900 MHz (UMTS).
Try your SIM in another phone to confirm it is activated properly (or at all).
@lyonsj2 that is a chance your phone is not compatible here, what exact model is your phone?
But to be sure, put your PM sim card in another phone to test as well.  It could also be a sim card provisioning issue and not device
FYI, phones have to have these bands for it to work on PM network
Quigley
@lyonsj2
Change network settings in your phone to automatic.
Then restart your phone.
