02-02-2023 11:09 AM
02-07-2023 01:31 PM
Wasn't aware I was doing that. Perhaps I should read posted responses before I jump in.
02-02-2023 12:39 PM - edited 02-02-2023 01:14 PM
@BEERPlease refrain posting identical content to others as it does not help customers.
02-02-2023 11:27 AM - edited 02-02-2023 11:28 AM
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
02-02-2023 11:14 AM
@jiggi you can first try to use the Reset Password link on the login page, enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
02-02-2023 11:14 AM
Hi @jiggi check if you have any welcome email from your mailbox, that would be the one you used
or open ticket with CS agent and they will reset for you
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
02-02-2023 11:14 AM
Look in all your emails for the welcome email from when you signed up or any marketing and promotion emails (not community). Or try any and all emails you can think of in the reset password screen and see if one arrives somewhere.
02-02-2023 11:10 AM
@jiggi To change email you need supports help
Watch for reply top of page to the
Right ( envelope image )
