Can't Register Sim
bhadfield
I am totally unable to register my sim card.
First I got stopped during the number port portion with the alternate number regex problem. So I followed advice from this community and restarted the process with the idea that I would choose a new number and then port my old one.
When I get to the number porting screen 1 of 2 things happen
1) there are no regions in the region drop down so I can continue
2) there is no region dropdown and the continue button is inert
mikefradette
Deleted
bhadfield
All good - I shortened my name and removed the space in the postal code. The form submissions worked.
Thanks for the help.
bhadfield
Tried using the advice. I still can't get past the "2. Choose Phone Number" step.
The continue button does nothing. I'll message a moderator but I'm having serious second thoughts.
First read this before you try again:
http://productioncommunity.publicmobile.ca/t5/Getting-Started/The-Guide-to-Headache-Free-PM-Signup/m...
When you do try activation:
- DO NOT port-in your current number duing activation; take a temporary number
- clear your browser's cache and turn off any ad/popup blocker
- if your name(s) is longer than 10 characters shorten it
- be sure your postal code is entered WITHOUT spaces
- choose any valid Canadian number as “Alternate” that is not your own
If that fails follow the directions in this link:
http://productioncommunity.publicmobile.ca/t5/Announcements/Information-required-before-sending-a-me...
Channel your patient persona. 🙏
bhadfield
I just tried again on a new restarted browser (chrome this time) and it became unresponsive.
