Can not recivce any txt msg
12-05-2022 11:18 AM
Hi all,
I can not recivce the txt msg. I turn on/off for the imassage, using airplane mode. but still not working. I can send oout the txt.
Any suggest?
Thanks
Service
12-15-2022 07:35 PM - edited 12-15-2022 07:36 PM
@toppy Still having problems?
Best settings:
A. Settings >> Messages: iMessage ON; Send as SMS ON; MMS ON >> Send & Receive: should show phone number and Apple id email address
B. Texting should always work “if” you send to a phone number and not an email address and “if” you receive only on your phone number. So in your message settings......send/receive, only check your phone number...leave the registered email addresses unchecked.
12-05-2022 03:30 PM
Is the Cellular Data enabled in your settings?
12-05-2022 03:26 PM
have you tried signing out of your apple id and then signing back in?
12-05-2022 12:45 PM
@toppy wrote:@Yummy @hTideGnow Thank you for prompt replied.. I tried both with wifi and data. or either one. but still not work.
I restarted te phone couple time. but it is the same.(call , recivce the call and snd out the txt. no issuse)
Can you receive ANY SMS or it is just one sender who makes trouble for you?
12-05-2022 11:58 AM
HI @toppy are we talking about just one sender? or you cannot receive text from many friends?
ask as many friends as you can to send you text
12-05-2022 11:32 AM
Is the sender sending to your email address or phone number?
12-05-2022 11:31 AM
12-05-2022 11:26 AM
HI@toppy try to reseat your sim card
and make sure Mobile data and Wifi are both turn on and see if it works
12-05-2022 11:24 AM
iMessage uses your data so you have to be connected to Internet either through WiFi or using data.
Try using native cellular SMS system and not proprietary app.
