Text Not being able to recivce but sending is good on Andriod
Theengineer
Text Not being able to recivce but sending is good on Andriod, Should to work just however recently stop working , cant get an code text for services. how do i resolve this
8 REPLIES 8
@Theengineer
I merged your two posts since duplicate.  Does talk and data work?
You can also try a network reset of the phone.  Note: this will erase any saved wifi passwords.
In your messaging app, you can also try to clear cache.
You could also put your SIM card in another working phone.  That will help determine whether hardware issue versus PM service probelm.
Theengineer
i can send but cant receive.
Theengineer
should have mention, i didnt , used to work just fine till last week
TheSterlinger
@Theengineer
try switching airplane mode on then reboot your phone, and turn it back off.
Did you recently port your number?
As soon as you sign up with PM you are assigned temporary number so yo can SMS and call out. If you cannot receive calls or SMS that means your number is not ported properly.
Theengineer
my phone has been working for fine and i didnt change my service.
TheSterlinger
Are you able to receive texts in general?
Theengineer
Text Not being able to recivce but sending is good on Andriod.
Was able to recivce for along time but suddenly has stopped working.
Please help.
