12-04-2024 09:13 AM
12-04-2024 11:54 AM
I had the same issue, but rebooting my phone fixed it.
Hope it will help
12-04-2024 09:17 AM
hi @Varma
reboot your phone first
try reset network settings. try changing the network mode, test all different one
check any outage in your area: https://www.telus.com/en/bc/outages
if same, ask support to check .
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
12-04-2024 09:17 AM
@Varma try rebooting your phone, if this doesn't work, do you have another phone you can try your SIM card in to see if it will work there? Otherwise you can contact a support agent:
12-04-2024 09:16 AM
@Varma Does text and say work ? Try rebooting the phone or reset network settings and see if that helps , can you try sim in another phone and test ?
also check
Outage map in your area:
https://istheservicedowncanada.com/
If account active and no outage and reboot or reset network setting didn’t help
you can use the orange chat bubble bottom right of screen or send a private message To CS_Agent
