06-16-2026 04:56 PM
Recently joined PM. Having trouble making phone calls. States “HB 1” , can not call the number .
a month ago
Try adding 1 in front of the number. Also reset the Network setting and reboot your phone.
a month ago
hi @Toshiko
since you just you recently joined PM, were you ever able to make calls?
what phone do you have? Check if your phone is on PM's VoLTE whitelist:
https://www.publicmobile.ca/get-help/articles/volte
and try Reboot phone and click Reset network settings
also check any local issue:
https://www.telus.com/en/ab/outages
if same, ask PM support agent to check your account. Please submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
a month ago
Did you reboot the phone and Reset network settings?
