01-26-2018 01:03 PM - edited 01-05-2022 03:58 AM
If you put an active public mobile sim card in a phone (Rogers network) and the phone is able to connect to the network and make calls, does this mean that the phone will also work on Telus network using a Telus sim card?
EDIT: assuming phone is unlocked already.
01-27-2018 01:40 PM - edited 01-27-2018 01:41 PM
wrote:I tried the sim card, but it did not work, the phone was a Nokia 5130, I guess its not compatible. I could not find information on the frequencies it uses.
The specs I found for the Nokia 5130 say that it is running GSM protocol only. Telus / Public Mobile's network do not support 2G GSM - your phone needs a minimum 3G UMTS/W-CDMA/HSPA: B2 (1900) and B5 (850)
The only network in Canada this phone will work on is Rogers, its sub brands (Fido, ChatR) and some MVNOs (SpeakOut, PetroCan).
01-27-2018 11:30 AM
01-26-2018 01:34 PM
That indicates the phone is unlocked.
01-26-2018 01:19 PM
If the phone works with Public Mobile, it will definitely work on Telus as Telus is the parent organization of Public Mobile. If your phone is locked to the Rogers network, you will need to get it unlocked first before it will work with another phone carrier.
