03-27-2019 12:51 PM - edited 01-05-2022 03:58 AM
03-27-2019 02:01 PM
@Sekiro wrote:@Driss_ I believe Sprint and Verizon phones use CDMA? You might be limited to a band/frequency not available everywhere so which is why you experienced the same issue with Fizz.
@Driss_ if it's an N9009, then it's CDMA version and can't be used with any carrier in Canada as nobody operates a CDMA network here any more.
03-27-2019 01:15 PM
03-27-2019 12:58 PM
@Driss_ wrote:Hi,
I have a Galaxy Note 3 (unlocked) from Sprint and the phone cannot find and connect to the Public Mobile network. The phone was said to be compatible with Public Mobile. I transfered my cellphone service from Fizz for a similar issue.
Anyone has any information or solutions to this issue? Thanks.
Check willmyphonework.net for your exact model. It looks like some may not be compatible.
