Can/US plan
Jonnytk1
I upgraded to the new Can/US plan do I turn the roaming on?
DennyCrane
Just leave data roaming on all the time, then it'll be seamless when you go back and forth between the US and Canada. There's never any extra charges in PM anyway.
Jonnytk1
Thanks everyone for quick reply
@Jonnytk1YES SIR
hairbag1
@Jonnytk1
yes...good idea to do that when travelling to USA.
@Jonnytk1
Yes, you need Roaming enabled and connect to the T-Mobile network.
If you just switch to the new plan, reboot your phone by powering off then power on before turning on Roaming.
