Calls
08-29-2021 03:50 PM - edited 01-06-2022 03:15 AM
08-29-2021 05:17 PM
It looks like there is a solution on the other thread.
Factory reset of the phone. Hassle though. Need to backup phone first.
08-29-2021 05:17 PM
Tried that.
My data and messages work and calling did yesterday but not today
08-29-2021 05:15 PM
To further troubleshoot, if possible, try another carrier's SIM card (ideally not a Telus, Koodo or PM card) in your LG phone. Let us know if calling works.
08-29-2021 05:08 PM
@Lacrossemom you have another post already. let's stick with your own one and we will try to help there
08-29-2021 05:03 PM
Mines not working either
08-29-2021 04:01 PM - edited 08-29-2021 04:05 PM
@Lacrossemom wrote:Its a lg g7 thinq
@Lacrossemom there is something up with that phone, it seems.
See here from today also:
Calls will likely work in another phone, give that a try.
EDIT:
Can you go through this advice and see if anything helps: https://thedroidguy.com/how-to-fix-an-lg-g7-thinq-smartphone-that-cannot-make-or-receive-phone-calls...
08-29-2021 04:01 PM
first test your SIM card in another device, and is still the same issue,
Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent, and Submit a Ticket
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started.
- or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
- You’ll need to be logged in to your Community account for the link to work.
- please include in your message,
- your account number,
- your phone number,
- your account 4 digit pin,
- your Email address,
- Customer Support Agent by CS_Agent, will Response to your inbox by private message
Good Luck....
08-29-2021 04:01 PM
I can send messages and data is working
08-29-2021 04:00 PM
@Lacrossemom try reset Network as well...
08-29-2021 03:59 PM
Its a lg g7 thinq
08-29-2021 03:56 PM
@Lacrossemom is data working?
what plan do you have?.
does your phone showing Public Mobile on top of the screen? how about signal level?
any chance of Airplane mode got enabled?
you have a 2nd phone to test?? Put your PM SIM in another phone and see how it goes
08-29-2021 03:53 PM
@Lacrossemom wrote:My phone isnt making calls or receiving calls
Hi @Lacrossemom ,
What trouble shooting have you tried?
Here is some to try:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reset network settings
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
Can you try your SIM into another compatible phone to see if call work?
What is the make/model of your phone?
