Calls
Giffy
Can’t make a call or receive a phone call. When I call out it says call failed
@velcrow wrote:
Ok, putting the SIM card in another phone worked. I can now make calls and text. I sure hope it stays that way. Thanks to all who helped me through this.
This may not have been necessary. I also encountered an issue after Public Mobiel had a network outage within the last few days.  Calls would not work unless I manaully selected the 3G network or unless I restarted the device.  The service might have still worked in the original device.
velcrow
@velcrow autopay could fail occasionally.
But if it some of them can be sent just not all, then it is not an account issue
Did you try changing your network to 3G Only? and see if it works?
Try to put your sim card in another phone and see if any difference.  By doing that, it could force a sim reprovisioning and it might resolve your problem
If you don't have another phone, click Reset All Networks and see if it helps (please note that will delete your saved Wifi and Bluetooth connections and you will need to add them back after)
velcrow
Yup same thing is happening to me. And sometimes I can send and receive texts,  most times I can’t. Been this way all day. Yesterday was fine. Rebooted phone several times. Can’t be a pay issue cause I’m on auto pay.
@Giffy
Did you check if your account status is active?  To avoid browser cache confusing,  please login My account using Incognito mode to confirm account status
If it shows On Hold (Suspended) , then it is a payment issue.  Click "Pay Now and Resume Services" to make a manual payment
If it shows active,
  • first try to reboot the phone
  • If that does not work, change the Preferred network type or network mode to 3G only or WCDMA only and see if it works
  • Try to click Reset All Networks and see if it helps
  • and do you have another phone to test the PM sim ? just to make sure it is not a device problem.  Also, that can force a sim card re-provision and it could resolve the problem
  • Also, try the phone in another area if possible, it could be just a local network outage
if none of those works PM supports are your friends
@Giffy  Is your account active or on hold ( suspended) call *611 what does the recording say . Try to reboot phone or reset network work settings . Try net work in 3G see if it helps with calling  if all else fails please
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
