07-24-2020 08:42 PM - edited 01-05-2022 12:15 PM
I read a couple of other threads where people had similar issues. Didn't really find my answers there.
I only just noticed this on my phone, when I call a landline, my number and name does not show up at all, another PM user tried with the same results. Fido calls will show up.
The landline phone does have my name and number in the contact list already. Dialer settings already set to show caller ID. I could have sworn that a few months ago, the number and name showed up properly on the landline.
I want my name and number to show up on the landline, any ideas?
07-25-2020 07:41 AM
@Tweetynumair first switch back to network default from show number on the cellphone. Second, the problem probably is with Altima Telecom try unplugging power supply from the voip box, waiting a couple of minutes and plugging it back in. Once it reinitilizes itself. Try the call again. Hopefully this works. Stay safe.
07-24-2020 10:53 PM
I have tried the caller ID setting, changing from network default to show number, still doesn't show up tho. Tried the *82+landline number but all I get is the "you don't have a voice plan" msg. Tried the network reset and reboot, no change.
Thank you for all the help and ideas! Stay safe👍🏻 I suppose since it magically started doing this, it may decide in a few months to show the name and number again....
07-24-2020 10:30 PM
@Tweetynumair I'm not sure what the problem is. To hide/ show your number on your xiomi a2 - Tap Call settings. Tap Caller ID. Tap Caller ID. Tap Hide number or Show number. You can check if this is on. (Also try dialing *82 before calling your landline. Is the number showing up now?) If this fails try a network reset and restart your phone if it doesn't automatically do so.
And I'm fresh out of ideas. Stay safe .
@Nezgar , @Jb456 , @sheytoon , @computergeek541 and @Korth amy ideas? Thanks.
07-24-2020 10:01 PM - edited 07-24-2020 10:02 PM
@gblackma xiaomi a2. Nope, haven't hidden my number that I know of. I did try in March to hide my number on a per call basis by using *31. But after testing, nothing i did worked to hide the number on the landline so I stopped trying. Now, of course when I no longer need or want it, it works without me even trying😑. Could I have done something then to make a change in the settings inadvertantly? But I'm pretty sure it was still showing my name and number when I gave up....
Landline is with Altima Telecom
07-24-2020 09:33 PM - edited 07-24-2020 09:35 PM
@Tweetynumair what's the make and model of your phone? And did you hide your number for business purposes and forget to remove it? Who is your landline with? Thanks. Stay safe.
07-24-2020 08:52 PM - edited 07-24-2020 09:04 PM
@gblackma 1 particular one that I've tried, don't have another one to test it on at the moment
*Update, apparently my number at least, will show up on another landline, so I guess it's just *my* landline provider that's having issues with PM......
07-24-2020 08:46 PM
@Tweetynumair is it every landline? Or a particular one? Thanks.
