Calls to USA
Demas11
I have tried several different phone numbers to Oregon and Washington and received messages stating that the number is not available .
Is my phone or the ability to call the USA being blocked?
Thanks for your time
Demas11
2 REPLIES 2
Demas11
@Demas11 ,
Are you on this plan?
And if so, are you calling from WITHIN Canada?
If yes to both questions above, do one or more of the below:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
* reset network settings
Will the calls complete now?
If not, check with the Moderators about your account.
To contact the Public Mobile Moderator_Team, there are two methods to reach them:
1 -  Faster - Click the bubble comment circle on the bottom right hand side of your screen, or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
Triguy
Do you have the US long distance add-on ?
1000 U.S. Long Distance Minutes - $15
Calls made to numbers starting with the following six digit combinations are not included in US calling from Canada and will not be completed when dialled: 712-432, 605-562, 641-552, 605-475, 605-477, 712-775, 559-726.
