Calls not coming through
yanminxu
I used a friend's phone to call my cell phone - the calls either 1) straight to voicemail or 2) doesn't ring on my cell. Can someone explain why?
Thank you
@yanminxu   It was working before but just have that problem today?  Or you just activated and never able to receive incoming calls?
Is outgoing calls working?
try to  first  reboot the phone
If that does not work, change the Preferred network to 3G only / WCDMA only and see if it it picks up incoming calls
If it still does not work, try to reseat the sim card.  Power off the phone, take sim card out for a minute and then put it back and power up
If you have another phone around, you can also try to put the PM SIM in the other phone try test it
JL9
What phone do you have? Is this rare or always been like this, could network/signal. Troubleshoot with the suggestions above and it should narrow it down
JK8
@yanminxu
Are you a new customer? Have you tried rebooting, resetting network settings, reinstalling SIM card. Is your phone unlocked?
Can you put your preferred network to 3G and try?
Can you try your sim in another unlocked phone?
@yanminxu
Few things to try,
1. Looking in your phone Settings to see if Do Not Disturb is turned on.
2. Reboot your phone by holding down the power button and Power Off the phone then wait 2 minutes then power the phone back on.
3. There might be a Telus outage so check the outage map in your area:
https://istheservicedowncanada.com/status/telus/map
