07-24-2024
06:33 PM
07-24-2024
07:25 PM
computergeek541
Hi multiple calls made to a number from my phone that I did not make. How do I stop this?
07-24-2024 06:39 PM
@Tammylake221 A clue as to whether they are voicemail is if they mostly end in 4001.
07-24-2024 06:39 PM
If that number ends with 4001/2 that is your voice mail calls go if you do not answer them.
07-24-2024 06:37 PM
@Tammylake221 This could be from checking your Public Mobile voicemail. Try calling this evening and then checking to see if there is an "unknown" number on your call history
