02-14-2022 07:36 PM - last edited on 02-14-2022 09:40 PM by computergeek541
02-14-2022 10:48 PM
happening just today? take the sim out and wipe clean first.
happened to me before once. Reboot didn't work until I took the SIM out like this
02-14-2022 10:02 PM - edited 02-14-2022 10:03 PM
Have you tried ALL of these:
02-14-2022 08:14 PM
What trouble shooting have you tried so far?
02-14-2022 08:04 PM
@Billsmith is your Do not disturb option accidentally turned on ?
OR, do you have the setting set where you only received calls from people on your contact list?
OR, did you recently port over a number into Public Mobile from another provider?
Cell ports can take 2-3 hours to complete. In this case you will need to accept an SMS text from your old provider's SIM card.
Landlines/voip number can take 3+ days to complete.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
If issues porting or transferring a number to Public Mobile, and it has been over the allotted time it usually takes to complete, submit a ticket here for help:
02-14-2022 07:38 PM
Hi @Billsmith
reset SIM, take out SIM, re-inserting SIM and power on,
try toggling airplane mode off/on,
try manually selecting network "3G only" or WCDMA only,
and Rebooting device..test it.
