Calls go direct to voicemail
12-19-2022 09:21 AM
When people call me, even those in my contact list, calls go directly to voicemail. It does not show the calls as recently called. I have checked all settings and had Best Buy recheck and all are fine. I was told it was likely a carrier issue.
please help
Service
12-19-2022 05:15 PM
Was it one of these items that rectified it, @Ljdion ?
- ensure airplane mode is not enabled
- ensure do not disturb is not enabled
- ensure the number calling you is not on a blocked senders list
- disable any call-forwarding features/settings
- turn off Bluetooth -- it's possible the 'ringing' is going through to a Bluetooth device instead of device's speakers
- remove and reinsert your SIM card
- reset network connections
12-19-2022 04:55 PM
thanks. The Chatbot put me to a tech and issue is now resolved
12-19-2022 04:37 PM
@Ljdion to me, they might have some kind of netoekr issue
which city and province you are at?
and open ticket with PM support and have them confirm.
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
12-19-2022 04:31 PM
Thanks. Tried but still an issue.
12-19-2022 04:30 PM
Thanks. I didn’t know about Service ticket so your reply was very helpful
12-19-2022 02:10 PM
This happens to me sometimes and my caller will just call me back and hope that it does not go directly to voicemail.
12-19-2022 09:38 AM
@Ljdion all calls go to VM without ringing at all? or just happen on some and not all?
and outgoing calls working fine?
Try this, first, reseat the sim card. Power off phone, take sim out for a minute and then put it back and power on
Then change the Preferred network type to 3G Only for couple days and see if it works. Try to have someone to call you when you are in different area, not just your home or office. This can confirm if it is a local network issue or not
Let us know how it goes
12-19-2022 09:24 AM - edited 12-19-2022 09:27 AM
That's been happening a lot lately.
You should have a Customer Support Agent look at your sim card and provisions.
Use the Chat Bot Simon to get a service ticket started first.
You'll find the link at the bottom of this page.
