06-14-2018 12:16 PM - edited 01-04-2022 06:11 PM
Now that it's official that call forwarding use up minutes, I continued my testing to see whether calls forwarded to disabled voicemail with extended absence greeting use up minutes or not. I can confirm that they don't use up minutes.
What about calls forwarded to regular voicemail where people leave messages? It will be longer than 8 seconds. Do they eat up minutes?
06-14-2018 06:25 PM
@LEGO wrote:If Android phone used, you may disable your Voicemail by following this route: click here
EDIT: Sorry @slpless, I just remembered from RFD forum that you have an iPhone.
Yes, haha. Thank you.
06-14-2018 05:11 PM - edited 06-14-2018 05:40 PM
06-14-2018 02:52 PM
Just to give you some background why I did this test.
As we now know, call forwarding use minutes for $10 50/50 plan. I don't use call forwarding, so that's fine. However, I found calls unanswered and forwarded to voicemail use up minutes. I didn't like it, so I decided to disable voicemail. Unfortunately, Public Mobile doesn't allow it. So, I used extended absence greeting to make it unable to leave a voice message. Whenever somebody calls me and I don't answer, it will be forwarded to voicemail. However, the caller hears a simple "Thank you." and will be disconnected. By doing so, there will be no minutes eaten up.
06-14-2018 12:33 PM - edited 06-14-2018 12:35 PM
According to the following it suppose to, but i guess it might be another goodie just like the long distance add-on 🙂
Uses minutes | Doesn’t use minutes |
- Making a call - Answering a call - Retrieving voicemail messages - Using call forwarding | - Calling *611 (the IVR) - Making or receiving calls from 911 - Using calling apps when connected to Wifi |
