Calls are taking long time to connect and once connected the call is dropped within a minute
11-22-2021 12:56 PM - edited 01-04-2022 05:08 AM
I have Samsung A10 e phone and lately the call take long time to connect and sometime it takes number of times to connect to a call. Once connected the phone call is dropped within a minute. This started happening since last week. Prior to that I had not problems with making calls. I need help, Is it my phone or is it the network issue. Sumsung phone did the last software update on October 25, 2021.
I am thinking of switching to Koodo or Virgin if this not resolved.
Service
11-22-2021 02:13 PM
Thanks for the suggestions. Public tech is helping to resolve it.
11-22-2021 02:11 PM
Thanks. I am dealing with Public tech staff. Hopefully they will resolve it.
11-22-2021 02:09 PM
@jay836 wrote:I have Samsung A10 e phone and lately the call take long time to connect and sometime it takes number of times to connect to a call. Once connected the phone call is dropped within a minute. This started happening since last week. Prior to that I had not problems with making calls. I need help, Is it my phone or is it the network issue. Sumsung phone did the last software update on October 25, 2021.
@jay836 Check these few tips:
- If you have access to another good working phone, try swapping the SIM card to see what happens. If not, at least try re-installing the card.
- Use 3G-ONLY (WCDMA).
- Do a reset network settings.
If nothing works and it's a network upgrade issue, not much you can do but wait it out.
11-22-2021 01:30 PM
@Tiprix Out of all the providers, OP only picks the Bell-Tellus alliance. 🙂
11-22-2021 01:29 PM
Please note if it is a tower issue, Koodo (Telus) or Virigin (Bell) use the same tower as Public Mobile (Telus). So switching to these providers would not resolve the issue.
11-22-2021 01:09 PM - edited 11-22-2021 01:10 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
- Open the Settings app on your Android.
- Scroll to and tap either "General management" or "System," depending on what device you have.
- Tap either "Reset" or "Reset options."
- Tap the words "Reset network settings."
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
try manually selecting network "3G ONLY" or WCDMA only,
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,
11-22-2021 12:58 PM - edited 11-22-2021 12:59 PM
@jay836 It could just due to network upgrade (there has been many network upgrade related to 5G and causing different issues, but usually those are short term only)
please first reboot your phone, then change your network to 3G Only and try to make the call again
