Calls and texts.
Jynxy2020
I can't receive calls or texts but I can make calls and send texts. Been happening since Feb 25.
Jynxy2020
I will try that when I have another phone here. I took sim card out to see if that would fix it but no.
@Jynxy2020  Can you test the SIM card in another phone to test ?
Jynxy2020
It's not a new activation and I never did porting.
@Jynxy2020  Did you just port a number into PM ? If so did you leave old providers sim in the phone to reply YES to the confirmation text ? And do you still have old providers SIM card ? I’m guessing it still works and the port didn’t complete . If that’s the case no worries I’ll private message you the porting team number . Give them a call and they can re trigger the port request for you .
HI @Jynxy2020
is that a new activation? and you requested porting?
look like the porting was not done.  I sent you a phone number to your Community inbox  to call Porting team.
