01-28-2020 07:29 PM - edited 01-05-2022 09:14 AM
Got my account set up and checked out the usage tab which shows over 200MB of data used and calls made before we had sim card into a phone...?? Has anyone had an ongoing issue with this? Seems very odd to have data and a call for 0:58 recorded when it wasn't in a phone. I don't want to end up with charges for long distance or going over our data when we didn't even do those things.
Joining Public
01-28-2020 08:36 PM - edited 01-28-2020 10:07 PM
@SK_0382 wrote:Got my account set up and checked out the usage tab which shows over 200MB of data used and calls made before we had sim card into a phone...?? Has anyone had an ongoing issue with this? Seems very odd to have data and a call for 0:58 recorded when it wasn't in a phone. I don't want to end up with charges for long distance or going over our data when we didn't even do those things.
Could it be a time zone issue?
Incoming calls and calls that are redirected to voicemail are recorded in Eastern Time in the usage history. There is no AM/PM markers that would indicate the time of day.
So, if someone tried to call you when your account was already active (and your number successfully ported), but the SIM was not in a phone, the call would have been directed to your voice mail box - the number would be something like 778-581-4001 (this is my local VM number, yours might differ slightly).
Calls that are originated by your phone (= you are calling someone) are logged in local time.
I've posted an example with explanation here: https://productioncommunity.publicmobile.ca/t5/Discussions/If-phone-is-shut-off-will-missed-calls-be...
The data usage on the overview page is very close to real time.
However, data usage in the usage history is reported twice daily for the (roughly) 12hour period before. Again, ET, no 24hour clock or AM/PM markers so if you see, say 11:45 as data time stamp, it could be just before noon, before you put the SIM into your phone, or it could be just before midnight, after you put your phone in and your phone's settings allowed it to burn through some data.
All guess work, but this would tie in with my time stamp experiences.
As mentioned above, you pay for a metered feature (data, outgoing calls if on the $15 plan) before you can use it, and when you have used it all up it just stops. No overages at Public Mobile.
01-28-2020 07:50 PM
Itlooks like you inherited the number usage together with somebody's number
Can you take picture of your payment history for last 90 days or so, to show that you opened account after usage occurred.
Contact moderators they should be able to sort it out. Obviously a bug.
There was something similar with people switching from telus or Koodo, it seem to match their last usage, so when they moved over the meter didn't reset.
Are you porting in-house?
01-28-2020 07:41 PM
There is no overage charges. Having lots of usage before even putting the SIM card into the phone the very first time is not good. I don't recall seeing this problem being mentioned. You might want to discuss the issue with the moderator team. The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team.
