Calls Dropped
sbabcock
Since yesterday, both my Android and my wife's Apple device are experiencing blipping during calls and outright call dropping.
This is occurring in different location (many km apart)
I have reset the network on my phone / tried Airplane mode off and on - no change
Steve
9 REPLIES 9
@sbabcock
if one clicks on the options it provides it will eventually lead to creating a ticket. it's a basic system...
*customer support doesn't always respond promptly. please be patient and check your inbox every few hours to see if there is a response
CSA are available from
- Monday to Friday: 6AM- 10PM EST
- Saturday and Sunday: 6AM- 10PM EST
sbabcock
I gave this a try and now I'm just having trouble placing a call
Ho do I get Customer service - I seem to end up in the AI
@sbabcock
wcdma = 3g
remove and reinstall the sim card while the device is off. if it's not helping I would contact customer support and have them reset the network on their end.
sbabcock
I don;t see 3G as a network type on my phone - they're LTE/WCDMA, etc
sbabcock
Yes - rebooted and the issue is occurring at my home where we've always had good service.
It's also occurring at another location where other people use PM but they're not having a problem
Meow
Most likely short network outages not reported as 'real' outage.
brettster99
Have you tried to reboot the phone? Sometimes that works. Also are you in the coverage zone? Any potential interference that could be affecting the calls? If all of those are answered, you might need to submit a ticket to Customer support
HI @sbabcock , it could be a network issue  in your area
you can try to change the network to 3G Only and check if the calls are better.  If it is , leave it there for couple days before you change it back
If nothing work, try also to open ticket with CS agent and ask them to check if there is a known outage or equipment problem in your area:
to open ticket,  at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
I suspect that there could be network maintenance occuring. With stuff such as this, the problems often fix themselves over time.
