07-14-2022 06:24 PM - edited 07-14-2022 06:25 PM
I was excited to see new 4G plans, but none with calling to the USA. Deal breaker for me. Not even an add on
in fact, I don’t see that option for any 3G plans any longer either ? Is this correct ?
is my current plan, which allows unlimited calling to the USA from Canada , grandfathered? Do I get to keep it as long as I don’t upgrade or downgrade ?
Slightly disappointed …..
08-04-2022 01:41 AM
@jyb wrote:Yes but who wants 2G service. Spotty and poor audio at best. I live in Texas 6 months every year and 2 G will not cut it for me. They originally talked about activating volte service by fall.
I found 2g service on Rogers to not have of a clearly defined sound as the Rogers 3g network. There was defintiely a difference that I could hear. However, I say that only knowing that there were two options back then and was comparing the the sound on one network immediately after using the other. If I had only ever used the 2g Rogers network for voice, I probably would have been fine with it. It is still a digital signal after all. Even audio quality from carrier to carrier can different, sometimes based on the CODEC used.
08-03-2022 09:55 PM
07-18-2022 12:21 AM
I wonder how good that 2G will work. Will be interesting.
07-17-2022 11:04 PM
voice services as it will use the 2G network where available.
US Roaming Add ons : Decommissioning of US 3G (publicmobile.ca)
07-17-2022 11:02 PM - edited 07-17-2022 11:10 PM
@jyb Check your Plan Details on My Account and confirm if it is there still. There were posts about they no longer see the US roaming parts on the Plan Detials earlier. If you don't see it, open ticket with PM support to confirm
As long as it still on your plan details, you can still use the roaming after 3G shutdown .
Roaming data and text will work on both AT&T's and T-Mobile's LTE networks without any problem
Roaming voice will work on T-Mobile 2G network.
07-17-2022 11:00 PM
So will the US 3G problem be gone for me then and will now run on US carrier 4G?
07-17-2022 10:56 PM - edited 07-17-2022 10:58 PM
yes of course you will keep it as long you pay for the service and never changed.
your phone will automatically select the best available network for the service provided in USA.
07-17-2022 10:48 PM
I have the 60.00 per month USA Canada plan (calling while in USA) 8.5 . Grandfathered plan from 2019.. Does this mean I will again have USA voice coverage after the 3G is shutdown in the US
07-14-2022 11:10 PM - edited 07-14-2022 11:11 PM
If you only make occasional calls to US, the Canada to US calling minutes add-on is still available...
Canada Add-Ons
Any unused data or minutes will roll over to your next plan cycle.
07-14-2022 06:29 PM
@vacek wrote:I was excited to see new 4G plans,
WHY? Why does data speed is SO important to you or anybody? It is a PHONE. You want high speed internet, use real internet provider.
And you cannot have everything: either high speed or US calling...😋
07-14-2022 06:27 PM - edited 07-14-2022 06:36 PM
@vacek hi it is still in your 3g plan it's just an oversight with the new design just to clarify, if you already have a plan with US calling
07-14-2022 06:26 PM - edited 07-14-2022 06:26 PM
HI @vacek the US calling add-on is still there if you are willing to pay extra
But all the current plans, 3G or 4G no longer include US callings
07-14-2022 06:26 PM
new plan is USA is gone
but if you grandfathered has USA plan then keep it if you changed you will can't getting back.
