Calling and incoming not working..
02-02-2020 06:02 PM - edited 01-05-2022 09:18 AM
02-02-2020 06:36 PM
I rebooted my phone when I had the same problem and everything went back to normal. Also, someone else said remove SIM for a few minute the start it up again.
02-02-2020 06:13 PM
@Dhoncha did you transfer port your number over from another provider ? Can you do everything else, receive/send calls/texts? When did you transfer your number? If you did port, your port may be completing itself.
If you didn't port, it may be a sim provisional issue and you will have to contact a moderator. Click on the green questionmark in the white circle at the bottom right of your screen . This connects to the autobot Simon. Type moderator and follow the prompts to get to one (CLICK on account specific question and human and submit a ticket
@Dhoncha wrote:Why im not able make a call?
02-02-2020 06:12 PM
@srlawren wrote:
@Dhoncha well, you've given us very little to work with, so I'm going to say there's probably dozens of possible reasons.
"Little to work with"!? I'll go so far as to say, almost NOTHING to work with!
So, @Dhoncha , as per the questions asked, kindly provide some detail, because none of us have access to your account, and can't help in ANY way, with advice, without some clue about what's actually taking place.
02-02-2020 06:09 PM
Did you recently port your number ?
What type of plan for you have ?
02-02-2020 06:07 PM
@Staliger wrote:
@Dhoncha wrote:I have trouble making a call
@Dhonchais your account active? Do you have funds?
@Staliger funds are kind of irrelevant, since PM isn't a pay-per-use provider.
02-02-2020 06:07 PM
Are you a new customer? I'm guessing yes, since you've posted (twice, no less) to the Getting Started area.
What is your phone's brand and model? What happens when you try to place an outgoing call? What happens when someone tries to call you?
02-02-2020 06:06 PM - edited 02-02-2020 06:07 PM
02-02-2020 05:59 PM
