Calling Pizza Hut
Jrose11
I saw the posts for not being able to call Panago.  The same problem happens when calling Pizza Hut.  Can this not be fixed?
Got it thank you🤗
@Sansan @Jrose11
adding 1888 or 1800 or any area code on 310 numbers won't work
310-xxxx are  special numbers and suppose  will be dialed 'intelligently' without requiring an areacode.  Not just PM but  some cellphone companies don't recognize 310 numbers at all or not able to calls successfully all the time
You can open ticket with PM support if you want to them check and see if they can. resolve the issue
Sansan
Hey, did you try this number also?
Try 1-866-310-0001.
780 3101010 Edmonton area?
If not working still, use the orange bubble to create a ticket to see if PM can fix it for you.
