09-02-2025 01:19 PM
My phone (samsung A53) should support call recording but has no option for that. Is that something that is controlled and supported by Public Mobile?
09-02-2025 02:15 PM
Thank you
09-02-2025 01:53 PM - edited 09-02-2025 01:53 PM
@Dyrret wrote:My phone (samsung A53) should support call recording but has no option for that. Is that something that is controlled and supported by Public Mobile?
Hey @Dyrret
Due to privacy laws here in Canada under the Canadian Criminal Code, Samsung disabled the use of Call Recording. You can however, look into getting apps from Google Play that may work or you may need to find an APK site to side load it.
09-02-2025 01:27 PM
@Dyrret if you mean that you want to be able to voice record your conversations, that is something that is hardware functional, and if your specific phone doesnt have the capability, there are a few apps you can download that offer that feature. It is not a function of the service providers. Hope this helps
