11-20-2024 09:59 AM
11-20-2024 01:03 PM - edited 11-20-2024 01:03 PM
Where are you located? It would be helpful to know if this is just a local problem or some system-wide glitch.
I am currently in BC and we are experiencing a bomb cyclone. So far, no drop calls for me.
11-20-2024 11:28 AM
11-20-2024 10:21 AM
HI @Justin221
it is a common problem in the last couple days
try reboot the phone, try Reset network settings and try your sim in another phone
if same, submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
11-20-2024 10:10 AM
@Justin221 Are you a new customer or have been a customer for a while and this suddenly started happening? What phone do you have?
