Call blocking per call
10-04-2023
09:54 PM
10-04-2023
11:39 PM
computergeek541
Does public mobile support *67. I don't know if I'm doing it wrong or its not supported.
I dialed *67 xxx xxx xxxx
I also tried placing a 2 second pause between *67 and number. Both don't work.
I know how to block all outgoing calls. Not what i want.
Thanks
Service
10-04-2023 10:40 PM
what phone do you have? some phone has it on the device level
on iPhones , go to Settings>Phone>Show My Caller ID
Some Android phones: go to Apps > Settings > My Device.
or go to Call > Call Settings > Additional settings > Caller ID.
Select "Hide number".
10-04-2023 10:34 PM
That 31 code is per call, not permanent.
10-04-2023 09:58 PM
Thanks
But that enables it for all calls. I still have to disable it from what i just read. Do they have one on a per call basis?
10-04-2023 09:56 PM
hi @Nikita4ever
yes, PM has it, but it is #31#
https://www.publicmobile.ca/en/on/get-help/articles/call-display-and-call-blocking
