04-04-2020 10:28 PM - edited 01-05-2022 10:14 AM
Is a detailed record of individual calls available, and if so, how do I access it ?
04-07-2020 01:15 PM
On "View My Usage" I was able to find only the number of minutes used, not how many calls, to what #, or when. What am I doing wrong ?
04-06-2020 08:24 PM
@bandkbock wrote:I have 23 min. of usage on a CA/US Add-On 200 Min. To control my usage, can I find out how many calls there were, where to,when, and what charge, if any ?
View My Usage will give you all your calling details. No charges though. You paid for them with the add-on cost.
04-06-2020 08:13 PM
@bandkbock Which plan are you on? Thanks.
04-06-2020 08:11 PM
04-05-2020 07:17 PM
Thanks that helps.
04-05-2020 07:14 PM
Thanks.
04-04-2020 10:33 PM
@bandkbock wrote:Is a detailed record of individual calls available, and if so, how do I access it ?
You can access your recent call details by going into the usage history section of your account at selfserve.publicmobile.ca.
04-04-2020 10:32 PM - edited 04-04-2020 10:35 PM
@bandkbock there is no detailed account of call records available, unless you are referring to what is in the self service account. Transaction section. Usage history, Its for 90 days.
